murphyz
yeah I'm an Asshole, an American Asshole
i have a 22re that i got in a trade and do not need. and rob talked me out of the swap from 3.0 to 22re
it came out of a 94 pickup. it has the fuel rails, valve cover, complete lower end, water and oil pump, efi intake, 2 heads ( one good and one "bad"). the engine had a valve job done to it that was not done right and the valve hit a piston. i talked and showed it to the machine shop and they said the cyl. was fine. i also have the ecu and the harness from the same rig. i helped pull the 22re from the vehicle. I do not want to part out. i can deliver up to 15 miles from bossier for 50 dollars or right outside the base gates for free.
I am not using this engine because i have the 3.0 and want to transplant a 3.4 into it in a year. if you email i can send pics. I am working after 3pm so if you want call between 9am-2pm this week or on the weekend.
five four one nine four one 1287
the valve in #3 punched through the piston... the machine shop i went by on tues said the block is good but (of course) the head is bad and the piston needs to be changed.
- $600
ALL FOR 250 NOW!!!!!!!!!!!!!!!!
PLEASE MAKE AN OFFER BOUGHT NEW TIRES AND NEED TO HAVE THIS GONE!
- $600
