Custom Lane Change Module
H0LLYW00D
Active Member
I put in a set of LED replacement bulbs from Recon and I am having trouble with them after installing a new signal light module.
The way the module works is you soft touch the signal light switch and it will flash the signals for 6 more times. With the LED bulbs in the module only flashes the insturment lights and the LEDs in the mirrors, but the front only work when you activate the signals all the way and the back dont work at all.
When I put in the original bulbs the front and rear work normally but the fronts dont flash when i use the lane changer module.
The front bulbs are a dual filliment bulb, not sure if this will make a difference or not.
Anyone have any ideas? or questions that I should get answers to get the whole system to work with LEDs.
I know the most LEDs have to have a resister for them to work with a flasher, this may be the problem.
H0LLYW00D
Active Member
well i gave up on the module for now, apperently with the LED lights there is not enough resistance for the module to work and also because the front lights are also the DTRL i would need to bypass the relay for the fronts to work, might try it again after i get some other mods done to the truck. if anyone is electrically savy and would like get this working from me let me know and ill send you the wiring diagram for the module and see if i can get a new diagram that i could give to an installer to have it work.
