3.0 to 3.4L swap (3VZ-E to 5VZ-FE)
how is that?
I carry a map torch on most of my trips (especially if I have smores materials). All you would need to do is keep solder in your tool bag. :D I've seen brass ones crack where you could patch it... that's all.
I figured it was something along those lines. You definitely can't solder Aluminum
No and although you can epoxy the tanks (sometimes with luck) but most of the time you're hosed.
I just pulled the old exhaust crossover. I should probably get some new gaskets before I install the new one huh?
Yeah. Those will be a bitch to change later if they leak. The risk is not worth saving a couple bucks on gaskets.
Cool, I called O'Reilly to see if they had the right size, but they put me on hold. So, while I was waiting, I went to RockAuto.com and was finished ordering before they picked the phone back up. Good thing I'm not in a big hurry to get the motor back in... yet
The "Bomb Proof" motor mounts came in today
n0rth
Look forward to seeing this come together, I just sent a friend of mine a link to your thread he was asking about the same swap yesterday for his 95 4runner.
n0rth
I'm sure he will be lurking your thread and sign up for the board so he will probably be hitting you up.
I'll PM you, and anyone who would like to know
I'd like to know, I did a lot of research before I changed mine out and those were never even mentioned? Plus they all look like single electrode and the 3.4 uses dual electrode plugs.
Just made a call and learned some more about spark plugs. Even the double electrode plugs only ever spark on one side; whichever side has the least corrosion/ wear and therefor the least electrical resistance. It just makes for a more reliable spark. THESE single electrodes should be plenty reliable
