4Runner Coil Spring to Leaf Spring Conversion
Started the coil to leaf swap today on the 4Runner. You have to unbolt and remove all of the suspension component's plus the gas tank so you have enough room to cut the front link mounts off.
Everything unbolted
Gas Tank Removed
A little bit of preliminary cutting
A lot more cutting, the rest had to be ground off
Eric showing some mad skills
Panhard and tow loops cut off
Ready for the new spring hangers
Cut off the rest of the tow loop and ground down enough so the shackle hanger will mount flat
Cut more off of the panhard bracket
Having clean weld surfaces is critical for making strong welds
Shackle Hangers Burned in
Well ladies, I'm kicking myself now for not taking pics while we had it down on all 4's. The U-Bolt flip was giving us some trouble so we decided to finish it up tomorrow. Here's the pics I've got right now
Because of where the spring hangers ended up being located, we cut them so they were symetrical instead of sloped
Hanger is 1" from the front of this hole in the frame. There is MILES of room for longer leafs for anyone (Rob) who's wondering
Some how Andy and I actually measured correctly and everything lined up the first time so we didn't have to cut any of our tac welds
We also had to modify the spring perches because the T100 axle tube gets fatter and more square further in
The radius on this side had to be opened up
We just cut this side straight across since the tube was flat
These leaf springs are barely adequate. With the weight of the 4Runner on them they are almost flat, so I guess I'll be buying some Dakars sooner than I thought.
Found out first hand how tight of a squeeze a 3" radius ubolt flip kit is on a Tacoma/ T100 Axle
I got creative and made a tool to force it in using one side of a ratchet strap
A pic of the crappy leafs. Randy's suggestion to flip the brake lines worked. Now I just need to bend them a little.
Still gonna need a longer line though.
Side shot of the tires sticking out of the fenders
And the money shot you've all been waiting for. Check out that sexy wide stance!
Put the gas tank back in, reconnected the driveshaft, and removed the e-brake cables. Then I pulled this hoe out to see the light of day for the first time in a month.
Here you can see the extended wheel base. The wheel well will look much better once I finish the wrap around bumper
I really need an alignment, but it looks like the tires stick out the same front and rear
The Stock Tacoma Springs weren't stiff enough, so I got some Dakars
pics of Dakars or shock mounts
Custom Shock mounts. Fit a 14" travel 5125
Some better pics of how well the rear shocks are protected
And the Rear Suspension Travel pics
Cool project Drew. I really should have relocated the hangers and put some longer leafs under mine. I'll be looking forward to seeing how you do this.
Where's my popcorn smiley?
Nice!
Added more pics. All the parts came in from in from Trail Gear so tomorrow we'll be guessing where to put the rear axle, lol
Nice, the guessing where to put the axle thing is what turned me away from doing longer leaves. Let me know how you decide to do it.
Nice work Drew, pretty interesting swap.
Drew, what are the benefits of this swap? I am assuming flex? What springs did you use?
Easier to swap an entirely new rear axle under the truck, t100 rear to match the width of the front.
I like the surgical scissors/clamps you have on the brakelines drew. Thats a damn good idea.
What Randy said + it should tow WAY better
I took the 4.56 ARB 3rd out of my Taco before I sold it and it's going in the 4Runner in a T100 housing. The track width will match the front now that I've done LT and having a stronger axle is always nice.
