Glad I searched for a dual battery setup thread before starting a new one.
@tex and I have been discussing dual battery setups and figure this might be a good place to record the output of our research.
We are still currently building setups, but I think Aaron has most of the parts necessary.
Rig: 2014 4Runner TEP
Fridge: ARB 37L (I Think....may be 35L...whatever size is closest to that is what I have)
Other electrical accessories: 30" Opt7 Lightbar
Battery Tray: C4 Fab.
Battery: To be purchased.
Leaning toward the Duralast Group 35 AGM to go in as the starter and use the OEM starting battery as the house battery. OEM starter battery is an 80D26L....which according to BatteriesPlus is just a Group35. Given that we are halfway through 2018 and we bought the 4Runner new in January 2014, it's at least 4.5 years old. We have a newborn in the house and I'm not about to leave a 4.5 year old battery as the starter and risk leaving my wife and two kids stranded somewhere during a Texas summer. Once the OEM starter goes, I'll look to put in something else.
According to
Choosing a Battery for your Overland Rig, The Duralast battery is made by Eastern Penn, which is preferable to Johnson Controls. He also states that for running a fridge, a deep cycle battery is not necessary. While deep cycle was a strong inclination at first, the warranty on them is significantly shorter than that of a regular battery. I like the idea of being able to completely drain and recharge regularly, but I also like the idea of just going to get a new one when it takes a crap. I'll probably go with the Duralast Group 34M AGM battery as the House battery when the OEM one finally craps out. Reason for the 34 is it is a little shorter than the 35 and should fit in the tray just a little better. A Group 27 should also fit if it has a flat top with nothing but the posts sticking up, but that is specific to this rig/battery tray setup.
It is worth noting that
Reserve Capacity is more important than CCA when selecting a house battery.
So, we've got the essentials:
- The rig
- the battery tray
- the battery
- the accessories to justify the fridge.
Now lets talk about the other things needed.
Solenoid
I'm looking to get one that has a built in VSR (Voltage Sensitive Relay).
Per
Dual Battery Systems | Alternator charging, how it should be done,
The Enerdrive VSR has one more huge advantage in that it is Dual Sensing (bi directional), what this means is that if you have a battery charger, or solar power connected to your auxiliary battery, and that battery gets charged enough to hit the Enerdrive VSR's set points, then it will allow your charging source to back charge the cranking battery as well, making sure that it's kept fully charged too, but again, if the voltage drops below 12.8 volts, the Enerdrive VSR will again disconnect (isolate) the batteries, so how cool is that
140A Voltage Sensitive Relay - Enerdrive Pty Ltd
The WirthCo Battery Doctor is recommended by
Van Living | How to Set Up a Dual Battery System and allows you to easily jump start without the use of cables.
https://www.amazon.com/gp/product/B...=B004QCDE9M&linkCode=as2&tag=bestvaporiz0e-20
Battery Fuses
I'm torn here. I'm between getting two 100A ANL/MEGA fuses and getting two 100A breakers. Cost seems to be about $22 regardless of which direction I go. I believe I need two of them, one for each battery. I have no preference to brand, these links are just ones that came up first on Amazon. I may try to see if I can source some locally for less.
ANL housing and fuses:
https://www.amazon.com/InstallGear-...UTF8&qid=1526407660&sr=1-5&keywords=100a+fuse
https://www.amazon.com/Absolute-ANL...TF8&qid=1526407660&sr=1-11&keywords=100a+fuse
Breaker:
https://www.amazon.com/Jex-Electron...TF8&qid=1526407660&sr=1-25&keywords=100a+fuse
Accessory Fuses
While I really like the BlueSea stuff, I don't like spending twice as much for a similar product. I think I'm going to try the OLS 10 fuse block
https://www.amazon.com/gp/product/B00QMULSUI/ref=ox_sc_act_title_1?smid=A1EQP448COWZL4&psc=1
Connection for Fridge
Aaron is using the Cllena Triple function piece found here:
https://www.amazon.com/Cllena-Funct...rds=cllena+12v+dual+usb+and+cigarette+lighter
While I like the idea of the blue readout, this Ginsco gets more stars and has more reviews:
https://www.amazon.com/gp/product/B01GC496T8/ref=ox_sc_act_title_2?smid=A2JU42WM4PJ26Q&psc=1
I also like that the Ginsco comes with switches, so I can kill power at the back if I feel the need. Plus $5 is $5.
Wiring
Pretty sure I'm going to run either 4 or 6 gauge wire between the two batteries.
Am I missing anything? What has everyone learned about various options? Is there something that I should be doing differently? Eventually, I may want to add the option to charge via solar, but I'm not there yet. Anything I need to consider to add that in later?
Other useful links:
https://www.treadmagazine.com/how-tos/charge-dual-battery-setups/
How to make a cheap isolated dual-battery setup for $50 <-- really liked this guys write up. Have not yet read the entire thread.
