So after dragging Tex's hitch rack around BBRSP a few years ago I have been thinking about a better expo hitch rack. I liked having the extra storage space but did not like tearing up the rack/ trail with it.
I decided a good expo hitch rack would need to:
1- maintain a good departure angle
2- stay tight to the body so as to not reduce turning radius in tight areas
3- have a decent sized cargo area for multiple fuel cans, firewood, or other expo essentials
4- allow access to the tailgate/ rear cargo area without having to remove the hitch rack
The rack I came up with the materials I had available with a 36" x 24" cargo rack that slides out 16" and is 8" above the hitch. The lower part is built with 11 gauge 2"x 2" tube but I plan to redesign the current piece for better support. The slide part is two 2" pieces of angle welded to the cargo rack so as to trap the top part of the hitch mount between the pieces of angle. This time I used a grade 8 bolt to keep the cargo rack secured to the hitch mount and limit the overall travel.
The materials list for this build was what I had on hand: 2"x 2" 11 gauge tube, 2"x 1" 11 gauge tube, 1"x 1" 14 gauge tube, a lot of 1/2" square tube, some 3/4" angle, and some 1" flat bar. I will try to get a better layout drawn up for future reference. I did buy the waterproof LED light bar off Amazon because I wanted something better than the standard reflective tape. Link
And now some pics... .
I am open to other ideas and will post some up as they come to me. I have thought about adding a small vertical thing to the front so as to allow for shovel/ ax mounting.
