Jakes 1994 FZJ80 (Big Orange)
I bought brand new.. shipped directly from BFG.
Edit.. Yes Randy they are on the Raisin.
^^^fapfapfap
TNRunner
Seniors' Member
rear housing had to be clearanced. Really demonstrates the difference in thickness, therefore strength, between OEM and these Nitro gears.
TNRunner
Seniors' Member
Ordered new lighting from Steve at Southeast Overland
13.5" Lifetime LED dual row bar for front, and a 3" 6 LED cube for rear.
TNRunner
Seniors' Member
So, my buddy that installed the 5.29's and crawler gears for me was going to deliver the truck to my house yesterday. Before loading up he decided to do a test run on the rock pile behind the shop. Dropped it in 4Low,first gear, center diff locked, front and rear diffs locked and it climbed great, then POP! He got under the truck and found that all the new torque had ripped the trans mount in half! So, new HD deisel LC trans mount en route. Glad he found it now and not during my trip in Februaury.
lol, pretty sure I told someone a couple months ago that the trans mount would be the first to go with a lower crawl ratio...
The 5.29s would actually reduce the load on the tranny mount, but even in a stock configuration that thing gets pretty tore up.
TNRunner
Seniors' Member
Yep. you called it. Sheared it in two!
TNRunner
Seniors' Member
Got two weeks to get this thing ready for WindRock. The list includes...
- purchase and Install winch
- purchase 37's (sold my 35's)
- install front light bar
- install reverse light
- install CB
- Install rock lights
- mount ARB switches in dash
- purchase and install fuse block ( blue seas)
The tantrum light are cool... I've had two sets. Not overly bright but not blinding your spotter either. I'm keeping the control module and swapping out the lights for others. I have 5 pairs of Olympus Offroads 18v lights... not because I wanted to but because they hooked me up and they are bright as fuck... sorry spotter. :) http://olympusoffroad.3dcartstores.com/18W-Bolt-Rock-Lights_p_27.html Anyhow the Tantrum control module is fantastic as are in the standard lights. But you can you can use that light module for others.
