Mauzer's 02' Runner build
man your runner looks good i thought i might have saw you the other day but i think it was a 2nd gen not a 3rd
Thanks, I didn't realize your in SA...I thought you lived on the coast (i think your screen name threw me off). If you ever need any help on your truck let me know.
Went to Drew's on Friday and finally modded my skid, also did my plugs and wires which was kind of a pain in the ass. Upgraded to NGK plugs and wires but the best fail moment was that every single plug I pulled out was a single electrode! There is a sticker on the fan shroud that reads: WARNING: DO NOT use single electrode plugs in this engine... Gotta love previous owners
Ordering the timing belt kit, after that all my maintenance will be done and I can get back to buying the fun stuff.
We need to get the tool I made to hold the crankshaft pulley from Sam before we change that belt. Does the kit include the 2 idler pulleys? I would highly recomend that you get them, My wifes where shot and so where Sams. We should at least have them on hand just in case, could always return them if we decide they are not needed. I also recomend that you replace the water pump, even if yours is not leaking.
Even better maybe your harmonic balancer can be JB welded on as well
I can only hope that my PO was that awesome <sarcasm> they did put those awesome plugs in so fingers crossed
Parts ordered:
Mitsuboshi- Timing Belt
GMB/Koyo- Timing Belt Idler Roller
GMB/Koyo- Timing Belt Tensioner Roller
Genuine Toyota- Timing Belt Tensioner
Stone/KP- Camshaft Seal (2)
Stone/KP- Crankshaft Seal
Motorad- Thermostat
Aisin- Thermostat O-Ring
Aisin- Water Pump & Gasket
Bando- A/C Belt
Bando- Alternator Belt
Bando- Power Steering Belt
Anything else I need?
Red Toyota antifreeze since we will be pulling the radiator and upper and lower radiator hoses are optional. Otherwise looks like a really complete list.
I didn't put Toyota Red in it when I replaced the radiator, I used Prestone red...guess this would be a good time to convert
SamSter0077
Frack me..
i AM REALLY interested to hear how hard yours is compared to mine. I just bought a new crank bolt. Was going to put it in next week, then give the tool back to Rob. Where are you doing the job? Want help?
