maintenance and body work updates..
got my squeaky door fixed, hammered out some of the new dents and put some new TRD OR decals on to help cover up the dents on the bedsides
squeaky door
after dealing with the squeaky door for a while, i started to analyze the noise more..loudest when the window was all the way down and about an inch up the noise went away...noise was a metal on metal sound that you'd notice hitting bumps or even going around turns.
original diagnosis was a broken door stay which would require a body shop to go in and fix the broken bracket..after the recent door damage, i was taking the panel off to bang the dent out anyway so i had a look...
a nut that holds the lower window track in place had came off...luckily when i took the door panel off, the nut fell straight down making it easy to find...tightened down and no squeak!!
missing nut
how it should be
and to help cover up some of the dents on the bedsides..had some sockmonkey decals to put on after touching up the body damage with some duplicolor..
