Nope!
I wonder if Sears is still selling the Platinum Diehard Marine series.
Ok good to know. I think I recall the salesman saying the marine batteries were going to stay in stock but apparently not.Nope!![]()
Max-Coupler. Need to order it.
Just called CVT. Good thing I called. They had my name all jacked up, first name and last name misspelled. Also had my phone number wrong.. Also found out its on back order to an estimated middle of June. Oh well.. that works for me actually.
Why not BatteriesPlus?I think I'll go group 31 Odyssey. VatoZone can order them in.
I should have checked on mine. I may have been able to rock that Booshi brand too.The X2 Power group 31 has the same specs as the Odyssey but its about $50 more. I'll save some $$ and go AutoZone.
http://www.autozone.com/batteries-starting-and-charging/battery/odyssey-battery/832146_690317_0
SLI31AGMDP - X2Power Premium AGM Car and Truck Battery at Batteries Plus Bulbs
I wonder if the VP of Engineering for ProComp is the same as SmittyBilt?Ok, so I was trying to wire up the brake away controller. It said to wire in this Deutsch connector however I did not have it. Called Smittybilt and they transferred me to the R&D department and I spoke with a guy in charge. He asked if I had the box with all the wiring harnesses in it. Nope. Apparently there is a change to this. I will need to remove and replace a bunch of wiring inside the frame.. yeah.. sounds fun <sarcasm> Anyhow, he really was helpful and sent me the PDF instructions and is overnighting the box which contains everything else. Anyhow, very happy with their customer server despite the initial trailer instructions. To be continued.
And it is always good to know where what is. Or was he on first?LOL.. I just wonder why they let it out the door like it is. I mean if they are including a new wiring harness they expect the end-user to swap out... I think that should be something they address before it leaves the factory. Now that being said I don't really mind because this gives me a better understanding of how the thing is wired up and prepares me a little more should it encounter a wiring issue along the trail. At least I will know where things are ran... not that there is much to a trailer wiring.
