The Bird's TRD
BirdTRD
beLIEve
Its a 2009, double cab, short bed, TRD Off Road. Not everything has pictures but most of it does.
Front Suspension:
-Built Right UCA's
-5100's at 0.85" (Changed to OME 90000)
-Eibach coils (Changed to OME 886)
-0.5" top plate spacer driver's side and 0.25" plate passenger's side (Since Removed)
-Removed sway bar
Rear suspension:
-5100's
-TSB leaves
-Wheeler's Offroad AAL
Homemade:
-sliders
-skid plates
This transfer case skid was slapped together fast and the welder wasn't cooperating. It will get a redo.
-Rear bumper
attachment.php
-Front bumper
attachment.php
attachment.php
Other:
-Cobra 75 CB
-285 Goodyear Duratracs
-Exhaust chopped behind axle
-Toyota bed extender
-Kobalt slim, low profile tool box
-Diff breather relocated
-Spidertrax front and rear
-Body mount chop
Coming soon:
-Winch
-Some skid plate redos
Looks good Greg! About time you put a build page together. Looking forward to seeing your front bumper.
Digging the sliders Greg.
garzanium
side bumper shot,bumper hitch and attachment point on bumper. Just trying to get some ideas for my own build.no biggy,im just saving most high clearence rear bumper pics for reference when i build mine
BirdTRD
beLIEve
I've made two rear bumpers and here is a link to each one's build. Both are pretty much step by step. Let me know if you need more.
The bumper I have now:
http://toyotaoff-road.com/threads/648-Homemade-Rear-Bumper-Part-Duh
The old bumper with the stock receiver conversion:
http://toyotaoff-road.com/threads/450-Homemade-Rear-Bumper
garzanium
Thanks for the links man. I tried to view your bumper build many of times, but like I have read on other posts, sometimes you can see stuff on here, sometimes you cant...so I copied each and every damn pic! Looking forward to working on my build,this helps a lot.Thanks again.
What browser are you using? I thought I was the only one having that issue since I use chrome
garzanium
yup,using Chrome.
Greg- thanks- hope to get started on some armor this weekend.Replicating your project failed as I have a Drop bracket kit-so those front bolts are already holding up the DB. Got some steel for this project then realized it was a no go!
^^ Longer bolts, have it hold both the DB and the skid.
BirdTRD
beLIEve
Thanks. One of the skid plates is pictured above. It follows the factory shape but is obviously made out of much heavier plate. I'll text you some pics of the front skid.
