Need some help and advice from some of yall more educated in the IT and network world than me.
New job requires an Ethernet plug to plug in and connect my VOIP desk phone into. The space I am going to use for my office is a room upstairs.
My modem and router are down stairs in the living room. The ceiling in the living room is tall and EXTREMELY little attic space above it so running cable through that part is not an option. I can run cable outside under the eve and bring it into 1 of the attics but due to the roof pitch and AC ducting there is no way to get close to where that cable enters the attic. Then once in that attic it has to up to the attic above the upstairs bedrooms to get it to the office.
With all that said, does anyone know of a solution that will be a strong enough signal for a VOIP phone? I know there is a WIFI adapter like this and I have this exact unit in the man cave for the receiver to stream Netflix but I have no idea what kind of data a VOIP phone takes or needs.
https://www.amazon.com/IOGEAR-Unive...8997&sr=8-3&keywords=wifi+to+ethernet+adapter
The wifi signal in the office space is good so that device in the link might be what I try unless someone has a better solution.
What about running a second coax cable into that room and having the internet provider run the line. Then set up a 2nd router on the same network?
