achirdo
2WD FTW
Run the garden house inside and zip tie to the shower head.
Now that you have bought some time pull up You Tube and watch videos on replacing the valve.
Or call a plumber and sit back with a cold beer.
I do like this option...
Is it just running out the tub faucet or no flow at all?
Just a trickle of flow from either
My shower valve no worky worky. Very limited flow. What are my first steps? Halp
Pop the cover off and make sure the mounting screws aren't loose. Take the shower head off and make sure it's not clogged up. If all that's good, watch a youtube video on how to remove a shower valve core and then pop it out. Look up the manufacturer and part # then go to home despot or a local hardware store and buy a new valve core (I've had better luck finding random cores at mom & pop hardware stores than Home Despot).
achirdo
2WD FTW
How tf do I take this thing part. I see zero hardware to disassemble anywhere.
Call plumber... open beer... observe... drink another beer... pay plumber... open 3rd beer... enjoy shower
you appear to have lots of minerals in your water, you can guratutee the inner valve core and seals are hosed and showerhead is probably has a ton of crud as well.
What type of plumbing do you have?
If PVC or Pex consider getting a water softner.
Galvanized or Copper, might want to look into at least a 3 stage water filtering system, it will prolong the life of everything in your house, pipes, faucets, hose bibs, fridge, ice maker, washer, hot water heater etc..
Getting closer to this.
Construction guys destroy your lawn or steal any more water since your last talk with em?
Nope.. they actually filled in the hole. They didn't fix the grass though. Said they would.
achirdo
2WD FTW
It will be one Allen screw on the bottom.
That's what I figured but unless I'm blind I can't see one. Even brought the flashlight out lol
I've got a little bit of everything. Copper, pvc, and pex. Different stuff based on what year it was touched last. House was built in 1956. Yeah we have really hard water here. I actually just cleaned out the shower head the other day. I've thought about a water filter for the house. Just major $$
Use the 1911 to open it up. Shot placement is key.
I can see outside now. Did I do it right?
achirdo
2WD FTW
I'd probably wait til next year to mess with it, or fertilize and water the shit out of it. It's a little too late in the season imo to get sod to get its roots deep enough to survive the winter.
Thats what I figure as well.
usually the faucets have an allen head screw as mentioned or the escutcheon ring will unscrew and provide access to remove the valve assembly. Perhaps the allen head is filled with minerals and corrosion lol
