Best alternative I've found is GE Sillycone2nd Gen Tacoma fender clips
OEM Part # 75396-35020 for the blue ones. You'll need 6 of them per fender.
OEM Part # 75395-35070 for the orange clips. You'll need 3 of them per fender.
They are expensive though...
Never had a flare move from fender. I have done this mod on 3 Tacos and no more issue. ~$6-7 a tube at Home Depot
To remove use fish line
Thanks for chiming in. I couldn't remember what you used.
Ouch! ICON wants $50 each for those rod ends. Their's are teflon lined. Let me see if I can find supplier for FK (OE supplier).ICON UCA uniballs -
FK COMH-16T -Wheelers have them on sale right now. I had two in inventory.
I think the heims are 1/2 20 rt thread. I will check. Ruff Stuff had bthem for $8 or $9
Only bummer is that they are coming from NJ so it will be a week. I can wait. I just worry people think I'm drunk when I drive it!View attachment 4211 Detective work complete. Ends are mounted inward - couldn't read them. A little clear tape did the trick. JM12T. $24 each at Poly Performance.![]()
Only bummer is that they are coming from NJ so it will be a week. I can wait. I just worry people think I'm drunk when I drive it!![]()
Whats good for you desert guys sometimes doesn't work so good over here in the swamps/saltbelt.Gotta love the bearing part numbers. I remember when TC was selling chrome uniballs standard and up-charging for stainless FK's. They gave me "racer discount" for stainless because my chrome ones only lasted 7 months. Got the FK part number off them then Googled it and found out "racer discount" was still like getting bent over. Started a thread warning others in snow belt not to buy them w/chrome balls then posted the link to the stainless balls that were super cheap and a year later TC swapped to stainless as standard.Whats good for you desert guys sometimes doesn't work so good over here in the swamps/saltbelt.
- They do use that line quite a bit! 'Racer Discount' means, "Guys that race spend a LOT of money on parts so they must not need a discount!" Sad. I do like the peeps at TC though. Sale on Uni-balls at Wheelers... 1" FK Stainless Steel Uni-Ball Bearing for Upper Control Arms, WSSX-16TPost up part numbers.![]()
Or $54 at Poly Performance.Sale on Uni-balls at Wheelers... 1" FK Stainless Steel Uni-Ball Bearing for Upper Control Arms, WSSX-16T
