Toyotacrawler's 64 M416 Restoration
Toyotacrawler
I think I just went 10-200
So for a while now I have wanted an M416 trailer and wanted a little restoration project as well. Well I found this 64 M416 sitting in a neighbors barn down the road and talked him into selling it. Wasn't that hard, he wanted to make a cattle trough out of it. Glad I saved it.
It pulled pretty good down the road on the way home....about 1/4 mile haha!
attachment.php
The plan is to restore it back to it's original condition. OD green and all the fixins. Since my fiancee knows how to paint with a gun, the paintjob won't require the use of rattle cans!
First order of buisiness was to clean all the dirt and cobwebs off. After inspecting the floor of the tub I came to the conclusion it will have to be replaced. No worries
It needs sandblasting so I began to break down the entire trailer piece by piece.
Took some persuasion but finally freed the tub from the frame.
attachment.php
attachment.php
attachment.php
After getting the tub out of the way I rolled the frame into the garage to begin the breakdown.
attachment.php
attachment.php
attachment.php
attachment.php
I'm pretty sure this is the original grease from 1964. It was like playdoh. I will install all new seals and bearings when it comes time to re assemble.
attachment.php
attachment.php
Cleaned up the brakes a little bit. Since the below pic, I've removed the brake assembly from the axle. Not much if any rust was found in the assembly but I will still replace with new parts and sandblast/prime and paint what I reuse.
attachment.php
So as of now the trailer sits completely disassembled and ready for sandblasting. I'm in the process of shopping for a sandblaster.
The only things missing from the trailer are the wiring harness, tail lights, safety chains and I will of course have to buy all new hardware due to the fact most of the rusted bolts sheared off during the breakdown. I haven't busted my knuckles that much since I hit puberty. More updates to come!
Toyotacrawler
I've thought about doing that but I want to try to keep it as close to original as possible. I'm not completely against it. More than likely once the restoration is complete I will put it up for sale. The way I look at it, if I restore it to its original condition, somebody that wants all original to match their old willys could buy it or somebody that wants to build and off road trailer would have a good solid foundation to start with. That's what I'm thinking now anyway.
