Sexy! Stack some fender washers underneath to get the clearance you need. Also, take into consideration a fully loaded fridge too when you add the spacer.
http://www.toyota-4runner.org/5th-gen-t4rs/192482-5th-gen-arb-fridge-install.html
I just followed this guy's approach. I think the difference is he used that rubber mat and I didn't. I think that gave him the height he needed. So I'll either find some rubber at work to use or I'll just pick up a piece of 1/4" plywood to put on top of the 3/4" I already have. It needs to come up some anyway because the plywood is only 3/4" and the foam that it replaced was 1" so that part of my cargo floor is actually lower and you can tell just by looking. But I'll have to get longer carriage bolts as well because I don't have enough threads to add another 1/4". Which means I have to unbolt the "adapter" from the floor of the Runner. And the way my back is, it looks like it could be a while before I feel like crawling around on the ground. But like I said, it works the way it is just fine, so I'm not in a rush.
