I had thrown those pieces away when I got my initial set of AllPoo "skids".. anyhow I had to resource a set when I went with Buds.
Had no idea about that. I've had Buds for a long time.I didn't realize the BudBuilt reused those pieces. I think all others, or at least most others, remove those 2 pieces.
Since I don't weld I found somebody at work that helped out here and got it done.Cut off the old nut, weld on the correct one. Done.
They still did. I had to modify it. Had to drill new holes because the rubber bumpers interfered with the metal straps. They were a half inch off which placed those straps too high and too low on the bottle. Would have slipped off too easily. Wish that wasn't the case...but reaffirms their crap.Its a bottle mount.. how bad can they fuck that up?
I have a popping noise from my front driver side when I turn left. The 3 months I had a quiet front end sure was nice though. Guess I'll tear it apart this weekend and figure out what is wrong.Swapped out both ball joints on my Light Racing UCAs yesterday. Now ALL my front end squeaks are gone....for now.
I made it fine, the vibrations only started over 65. Knocked a zerk off and small dent in the shaft. Rumbles like a bad u-joint or maybe knocked the CB up a bit? Seems like there's a bit more play in the CB now.Pull it out and drive home in 4WD.
Was a fun time. I might have gotten a bit overzealous or picked a bad line.Going to need some more info on that scratch.
