My mom popped off earlier and said "If all it needs is a new engine why don't you just put the one from your truck in it then sell your truck for parts." She knows not to tempt me with stuff like that. I'm almost dumb enough to do it!
Since she said it, I'd do it
I would if my dad hand't heard and immediately shut down that idea.
Was having this conversation with my dad on the way to pick it up. I would like to be able to drive it to the close trails like Bridgeport and Tolar. But other than those two I will trailer it.
Thoughts on what I should do about the engine? My dad thinks I should order a new built shortblock. But that doesn't sound very $$ friendly to me.
Sounds like waste. Get the one Rob has and slap it in there. Then if the other one isn't too far gone, rebuild it yourself the right way.
If your trying to be cost effective I would still see what is wrong with the motor that is in it first. If it can run again with minimal work; I would get it running and use the borrowed time to get another motor lined up. Get the motor from Rob, go through it real quick, drop in an RV cam and do all the 100k mile work that should be done to it. This way you can work on the motor as money and time allows; while your still able to wheel on the weekends.
LQ4 and be done with it.
I plan to see what's wrong with the current engine but I'm not going to mess with it for very long. Regardless if it runs or not it doesn't do me any good. It needs a new exhaust and passenger side leaf spring before it can be driven. I'm going to start on the electronics tomorrow. Get all the lights put back on and make sure they work.
You donate it and I'll do it!
