Drew02a 1991 4Runner, Long Travel Build
This evening, I relocated the rear window switch from the gear shifter surround to the dash on the driver side. Also power ran wires for my HAM radio and CB. Planning to run the antenna wires tomorrow when I have more light and then I'll give them both a test.
Come on up... I've got a bender.
For drivability:
Buy and install a new alternator
Buy and install front shocks
For offroading:
Finish modifying my front driveshaft. Need to buy new U-Joints then put it back together
Weld on my Sliders
Get on it the clocks ticking, and what dimension shocks do you need I've got some laying around
I took advantage of the cold weather and got a little work done on this thing
Gear drive transfer case was leaking pretty bad from the rear output shaft. So I pulled it off and hit it with a bunch of RTV.
Also, chopped and rewelded the shifter so it wouldn't interfere with changing gears.
Inchworm adapter? They're having issues with bearings
http://ttora.com/forum/showthread.php?t=198933&page=4
When are we wheeling this fucker? Inquiring minds want to know. <smiley here>
