License Plate Wiring
Got some work done wiring for the license plate light. I wanted to run the wiring through the tire carrier tubing. It was a huge pain in the ass.
I drilled the first hole too close to the weld. Aparrently, the hinge piece is inserted into the tubing then welded.
I tapped along the tubing until the tone change and drilled a second hole. Dead on...
Here's the first hole I drilled for the wiring to exit. I thought I could use a vacuum to suck a piece of string through, but that didn't work out.
3hrs later after drilling a bigger hole, I was able to grab the string with some tweezers that I had to modify in the bench vise.
Ran the wiring out above the tail light. I think I'm gonna use some smaller zip ties.
Ready to finish another day. I only ran one wire since the carrier is grounded.
