Did you build those 6x9 enclosures? And good idea for the square driveshaft and mounting it. I'd hate to have to ratchet stap up another one in the middle of the night.![]()
I did not.. bought them online for CHEAP! But they have great posts in the back and are built out of decent 3/4" MDF. I will be fiberglassing the shit out them to prevent moisture damage and it will also help in the sound department.
Yeah, I figure if I do my measurements correctly I can make one shaft to fit both front and rear. Since the thing has duals in it they DS's are similar in length.. I'll need to measure. As for ratchet strapping it up.. thats due to the pinion nut backing off... which reminds me.. I want to put a tack weld on that fucker!
Been thinking about how this is going to go next... I'm thinking something like this.
The side angled pieces will be leaning backwards from the middle tube... might move them forward more. It will all depend on how far out that middle tube goes and if it will interfere with my tire or not. At the top of the cab there will be two bars...one right behind the cab and then another at the bend in the downtubes. I need to do some "X" type back there so that will need to be worked in as well.
Might add a second set of side support.. I like the look of it.
