Humans are too, maybe the Covid is mother natures F250. And just like the hogs, hiding in the ditch ain't gonna save ya![]()
, then Trump needs to export more F250’s to WuhanHumans are too, maybe the Covid is mother natures F250. And just like the hogs, hiding in the ditch ain't gonna save ya![]()
, then Trump needs to export more F250’s to Wuhanwhich ones did you go with?
Ended up going with Moultrie A900. I like their story of how they started plus they got a few recommendations when I asked. I also like the ability to upgrade to cellular or 12v battery packs or 12v battery/solar down the line if I want to.
They now offer a 3 year warranty so long as you register them within 30 or 60 days and that's also pretty cool. I registered them as soon as I got them out of the packaging. Tested them indoors to see if they work in light and dark then placed them outside. I'll be making some sort of shield to keep some of the weather off of them. I took a walk in the daylight, at dusk, and at dark last night so Ill analyze the pics tonight and see what I need to do to get really good range and pics. Right now I have no pic delay so Ill have to change that because I'm sure it prob took 20 pics each time I walked by it.
You can see the red led "flash" for the IR so thats the only downside of not getting the A900I model that you can't see the flash of. I'm not concerned with that because I also have motion lights that go on so they will distract from the red "flash".
Pics will prob come out crappy because I had my motion lights pointing at one of the trail cams. Tonight Ill adjust them to both be pointing the same direction.
the one thing I'm not a fan of is they tell you to not use rechargeable batteries. I stopped buying batteries years ago so Ill need to look into that. I have a TON of Panasonic Enloop Pro batteries so I really don't want to waste money on batteries that just get thrown away when they are used up.
I didn't think of heat. Welp good thing you said that - I was going to fashion clear roofs out of 1/2" Lexan cut offs from work to keep them dry and now Ill use cedar to block the all UV's and rain
I was going to use two pocket screws and a lid with a 45* angle on the back to secure it to my fence posts separate from the cameras. Now Ill prob just use cedar.
all my jugs are full of old tacoma gas and wet and forget that I diluted/mixed up![]()
Mine has been in direct sunlight over 10 years and that has never happened.Good deal, I definitely recommend using the 12v external power cord with the 12v deer batteries, you should only have to charge the battery twice a year for your use. Batteries in the trailcams heat up from outside temperatures and direct sun exposure to the cameras and the batteries will corrode.
or just redneck it and cut a nursery bucket in half, and call it good,![]()
Ill post a pic later but I'm choking on plexi and lexan. you could build a few greenhouses with the cut offs we have from covid guards @ work. already filled my moms SUV up to the top once and my car once. Now my car is filled again today.
Off to go 'let people go' on my jobsites - this should be fun (worst part of my job IMHO)
Your neighbor looks sketchy AF.![]()
if I had a Halloween mask within reach I was going to wear it for the night walk but couldn't find itYour neighbor looks sketchy AF.![]()
