Yeah, now I can buy some of those 'cool' ones you run...now you can upgrade away from those queer pink tail lights.
Yep... bumper did its job too...At least it didn't get the sheetmetal.
just put on those shocks i got from drew man they are a pain to compress
I finally painted that rear passenger door. Used the paint from http://www.automotivetouchup.com/ Bought the sandable/filler primer, basecoat and gloss clearcoat. It turned out pretty good, not perfect but from more than 3-4 feet away you can't tell. I need to break out the polisher and give it the once over after I let the clearcoat harden longer.
same ones I tried to use? because hell yeah they are....![]()
I think a spray can will do just fine,Looks good Sean, Drew you need to hit that place up and see if you can get some color matching for your truck.
.I think a spray can will do just fine,.
....its your truck, that dupla color is some good stuff.I finally painted that rear passenger door. Used the paint from http://www.automotivetouchup.com/ Bought the sandable/filler primer, basecoat and gloss clearcoat. It turned out pretty good, not perfect but from more than 3-4 feet away you can't tell. I need to break out the polisher and give it the once over after I let the clearcoat harden longer.
Before
Then I had some bodyguy pull out the dents and make it smooth. I then painted it.
Did you get all of your scratches out? It looks flawless!!! I have so many deep scratches!![]()
I got 90% of the scratches out, I can probably hit it again with the polisher and get them out. I still need to do the roof, it feels like 600 grit. But that touchup paint system they sell really works. Best $50 I've spent in a while.
When you did the clear, did you do the whole door or just the spot? Did you use one of those spray paint 'softeners' before clearing?
or you can hit with 1k grit again using water then buff back the shine
yeah, I have some 1500 grit as well.
