The truck seems damn tall with the BL installed. My 33's look pretty small.
Next to my 5 year old for reference, you can make fun of the flowers she put in my antenna hole if you want.
Motor mount spacers are in.....sorta, they are just sitting there since I still need to replace one of the mounts anyways.
Still waiting on my Bud Built so I had to stick some 2x4's in the stock crossmember to lift the trans. The t-case sites much higher.
Found a motor mount in my shed. It's Murphy's but from what I understand possesion is 9 tenths of the law.
Rear drive shaft to horseshoe crossmember clerance once the trans was lifted. Not even a 1/2" - No good.
Todd helped cut out tthe center section and add this new piece.
Maybe this is why my exhaust sounds sooooo bad? This is right behind where the flange bolts to the exhaust manifold.
Damn the garage is a mess.
I still need to:
Modify the mounts and put the gas tank back in higher.
Replace one motor mount and get the spacers bolted up.
Fix the exhaust pipe and weld new (shorter) hangers.
Figure out what I am going to do for a transmission mount - My rubber mount is completely finished
Get my new crossmember, paint it and get it installed.
I worked my butt off on this thing over the weekend and it doesn't seem like I got very far. Thanks Keith and Todd for helping out.
