Well.. the TG flange kit comes with extra 5/16th's studs... no drill guide though. http://www.trail-gear.com/hubs-and-drive-flanges Ah fuck it.. I'll wait until I get back to decide.
Thanks Chris. But I think I'm going to go flanges once I get back from Hawaii. I'll be ordering TG ARP hub studs, a new outer flange and a set of Longfield chromo flanges.
I'll also be upgrading to PSC hydro assist and building a 3/4" heim steering setup using Sky's billet pitman arm.
Very nice. Now your hubs won't try to kill me again
LOL... yeah I just moved my weak link up the chain somewhere.
T-Case flanges?
T-Case flanges?
Input/output shafts then the trans internals.
Oh, and as for the input shaft.. the upgraded chromo 23 spline only works with the R series transmissions.![]()
Lol.. doubtful.. but any motor swap is way down the road.Is a V8 in the raisins future? :horndog:
Damn!!I have an extra R series in my garage, but i don't think it will bolt up to the 22-RE
Chromo flanges and ARP studs are on order. I went with the TG flanges because they have an O-ring to keep water out.
Next is to order some new hydro-assist gear. Probably going to go with the PSC setup. Need to do some more research first, but the first one listed below is looking like the winner.. just add a cooler.
http://www.pscmotorsports.com/toyota-22re-performance-pump-kit.html
http://www.pscmotorsports.com/toyota-22re-super-combo-pump-kit.html
http://www.pscmotorsports.com/motor...id-cooler-heat-sink-type-2-pass-aluminum.html
yep.. need to spend $600 on new chromo ones. My goal is to make my weak link the lack of horsepower in the little 22RE.
Are you sure?
Nice! If I was going to trailer mine, those flanges would be sweet - except they would cost me 2x as much!![]()
Have you seen any trans internals upgrades? I only saw things like cover plates and a few bearings.. and all that was for the R series trans. I have a W. Maybe at that time its due for a motor/trans swap.
Nope no upgrade trans parts unless you swap the whole thing out. On that note an nv4500 would be really sweet if there is an adapter for it.
