Nothing wrong at all. Just not for 2 weeks. The fumunda would be strong after 14 days
True. 3 or 4 days without a shower is one thing but 14 is another.
x2 for a tankless system. I have thought about what it would take to bring my Ecotemp tankless water heater on an expo trip with me.
Is there something wrong with wet wipes, baby powder and a quick spray of deodorant?
14 days is a show of true love.. Baby you smell like a locker room. Oh wait, so do I.
- I love to really feel clean - not just hide it. New diff seal is in place. Was no less a bitch getting the LCA to the spindle. Not sure WTF is the issue. Stock LCA's lined up easy peazy. But damn these make me want to throw things at it. Found some gunk in the bolt threads and cleaned it out with a small file. Then it went together. Not sure where it came from but damn. I'm ready for a shower and then bed! Fingers crossed it doesn't leak tomorrow when I test drive it. It was raining cats and dogs when I finished up so a test drive wasn't ideal.
I don't know the delta T (how many degrees it will increase in temperature from one pass) available from that unit but I figure I will have to run it through at least once when taking water from a mountain stream.![]()
I know my Ecotemp will bring 50 degree water up to 100 at a decent flow rate. Not a strong shower flow; but enough to rinse off with. I agree that a second pass would allow you to get a good temp and good pressure.
Those are nice. IIRC Sam has/had one. I have a Zodi that the wife bought me several years ago. Never used it.well other than to make sure it works but it did. I like that one better because you can control the temp. The Zodi just runs water through a coil in the propane fired heat box and makes it hot. So you get what you get.
I have had two of the EccoTemps.. one melted down, so they replaced it for free... second version has been problem free. It's also sitting in my shed not being used if anyone is interested in a cheap one.. I used mine with my first popup that didn't have a water heater. Worked great for shower, never had an issue with flow of hot water? it was much hotter than I needed really... Couple of D cells batteries and a water spigot was all I needed.
for roughing it with an RTT.. the little Zodi setup would probably work better or this one.. http://www.amazon.com/ZODI-Outback-Gear-Extreme-Shower/dp/B000RYWQP6
Do you use an external pump?
Yes; but I have a couple stainless steel pumps i use for brewing beer. At almost $140 each I am certain a cheaper option for this is out there for camping.
I do really like the Eccotemp system though.
The issue of hot water is I think about the fall trips that I have done in the Sierras - that water is friggin cold!!!
Sad fact: I have one of the extreme deals too. Just never used it. I guess I should!!! The shower nozzle broke and I need to replace it. I always thought the thing looked like an accident waiting to happen.
Think my Eccotemp will bring water up a max of 70 degrees as single pass. I bought the 180 degree shut off switch for brewing; I think it stops heating at 120 normally.
While swapping out that axle seal I noticed my brake pads are about shot. Also noticed my Goodridge SS brake line is not looking so good. Had one fail on me before. So I just ordered new pads and a complete set of Crown Performance brake lines.
