Its extremely difficult to use a plasma cutter with any precision. I actually use it as little as possible. The kerf is huge, like an 1/8", and its difficult to keep a steady hand. I use it for rough cutting only because then I end up having to grind a fair amount to get a clean line.
With all due respect, I think you may have thought that you had a laser cutter in your hands... what you are describing sounds like a plasma... the key for me is speed and being able to touch the part with out having to dunk it in water. The end result can be cleaned up with a grinder. For the very clean stuff, I still plan to use the stack of cut off blades for my grinder. - that's all
