It is. I briefly looked at that, but didn't fully check. Figured since it wasn't happening on day 1 it might not be it.Is that a single piece shaft? Mine made that on occasion too, it was the driveshaft contacting the old carrier bearing mount. I had to trim that mount back to keep from interfering.
That's not the issue. Plenty of room there.Is that a single piece shaft? Mine made that on occasion too, it was the driveshaft contacting the old carrier bearing mount. I had to trim that mount back to keep from interfering.
So...turned out the bolts at the transfer case weren't tight. They came loose a bit and since my transfer case skid plate was on I got lazy and didn't check those bolts and only checked the ones at the diff. My threadlocker and tightening job sucked. I found the time and made the effort to pull the skid plate this weekend and check. Kind of embarrassing really, but it's all good now.This just started today. Metal clank when shifting to reverse. Brand new driveshaft and the bolts are tight.
- YouTube
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.youtube.com
The CEL has been resolved by changing the air fuel ratio sensor on the driver side. The sensor itself was easy to reach, but the wiring clip was a bit tricky.Got my Tom Woods DS to install tomorrow and to diagnose a P0174 code.
Shit happens. Glad you got it figured out.So...turned out the bolts at the transfer case weren't tight. They came loose a bit and since my transfer case skid plate was on I got lazy and didn't check those bolts and only checked the ones at the diff. My threadlocker and tightening job sucked. I found the time and made the effort to pull the skid plate this weekend and check. Kind of embarrassing really, but it's all good now.
